DISH Network splitters
djeyes
I recently installed DISH network satellite and as a result of having only two receivers activated, the installer dropped two coax cables from the dish into my Leviton hub. As I expand my needs for additional receivers, do I have to drop more cables from the dish or can I split one of the existing cables and amplify the signal?
If DISH is anything like DirecTV you can not use regular splitters. You have to use a multiswitch. D* dishes usually have a 4 way multiswitch built in. Or, you can take your 2 wires and put it into say a 2x4 multiswitch.
You'd have to check specifically for DISH - maybe thismay help? Or do some searching around and I'm sure you'll find the right info. I like this explanation, but again it is for DirecTv.
Dish uses multiple satellites to support their channel lineup. Do you have a single Dish 500 system , or multiple dishes? Signals emanate from satellites at 110 and 119 degrees for most of Dish's channels. Hi-def and local lineups are on additional satellites, I believe.
Do you have two separate dual LNBs with switches, a single-unit dual LNB, quad LNB, or ??? Last year when I moved, I had to get a different switch to support up to 4 receivers. I originally had a Dish 500 with a single LNB unit that only supported 2 receivers. The new one is a 4 receiver system. So I have 4 coax cables come down from the dish.
However, it depends on the equipment you have. Dish Network does have a lot of different LNBs that are dual, quad, etc. and they all look pretty much alike. So first you need to know what is on the dish and then you can figure out what's needed for more receivers. In some cases you can use external switches, in other cases, you cannot. Since you started with 2 receivers, you may only have the gear that supports two receivers.
I had a booklet with all that info here somewhere, can't find it just now. There may be some of this info on the Dish website.
