johnlaroux said:I have CO2 sensors in my house so I know when to exchange the air. I just tapped into my 18" return air flex duct and ran an 18" flex duct to outside with a 20" x 40" filter rack to filter outside air. I put an 18" motorized damper in the outside air duct and an 18" motorized damper between my inside return filter rack and the duct tee that runs to the outside. The outside air damper is NC and the damper that closes off the return air from indoors is a NO and I just energize a relay to power the damper motors that have a spring return when the power to the dampers is removed. This gives me 100% outside air exchange which will exchange all the air in the house in about 10 to 15 minutes. This is just a hobby. no real concerns for health. Also works good to get rid of odors in the house from cooking.
I also track the indoor enthalpy vs. the outdoor enthalpy so as not to introduce energy to the indoor air that will need to be removed by the ac unit.
Wow, I have to say I'm pretty impressed. What type of CO2 sensors are you using?
My setup is a bit less "heavy duty." I have two HVAC units and each has an 8" duct going to outside with a 12x12 filter. First problem is 12x12 filters are hard to find. Each has a damper then it ties into the return. One unit has two 18" returns, the other has a single 18" return.
Because mine only works when the HVAC fan is running, I decided to add two booster fans, one for each air intake. I think that will work for me then I can run this all night since my goal is to use free outside cooling as well as ventilation. One unit is a 3 zone system, so I have three dampers on the output, but when the AC is off, all those dampers open.
I like your arrangement, but I have another question. When you have it switched to outside air, where does all the air go? You didn't mention any duct for exhaust. For me, I figure the exhaust vents I have for my three bathrooms and the stove hood should be enough, but my flow rate is not that high. For you, your flow rate is much higher, so do you have a problem with exit air?
Also, did you automate yours, or do you have to activate the dampers manually? I'm hoping to activate mine 1) when CO2 is high, or 2) when outside air can help heat or cool the house.
