Door mags in frame, but not in door
jokah
Hey all, I have recessed prewired doormags in my home from when the builder/prev owner had it wired up. Unfortunately, I am guessing this was done when there were temp doors, and they never added the other parts to the doors themselves.
I cannot tell who makes these doormags, theyre small/round. Only legible numbers/logos are UL and a BP#. Pulling up the BP, its just code for UL approved magnetic sensors.
I can take a picture for you guys, but I do not know if my cam will pick up what i cant see... so the question i have is, will any mag part of this work?
What else is needed to complete installation
cams better than the eye.
Does G2 mean anything to anyone?
Well, easiest way to test is hook up a continuity tester to the wires and wave a magnetic around that thing.
well in theory they work, so i am just wondering if it matters what magnets or used, or if i can mix and match
Oh, I think in regards to magnetic reed switches, magnets is magnets. Probably your real constraints will be where in the door you can place a magnet and how big the gap is.
Try to find some strong magnets to mount in the doors, stronger the better. I don't think brand matters.
Come to think of it, the magnets may be in the doors, covered with caulk/putty - that's what should be done to that sensor/contact, IMO.
The magnets will be in the doors, at the same level, puttied and painted.
Unfortunately, no luck on being in the doors, its raw wood.
Where im at they throw temp doors up right away, then the wiring was done. I am guessing they count on nto completing the job expecting to be called for full installs vs come back when homes finished to install mags
So how can i tell strength of the mag when I buy some to throw in the door?
Just get any 3/8" gap stubby press fit magnet and try it. It isn't much money. Just place it 3/8" near the sensor and look at the other end with a meter set to resistance (continuity buzzer) and it should 'buzz' when the magnet is near the sensor.
