I know the app I made that uses webview doesn't create multiple sessions. However, I'm experiencing a strange issue and I'm curious to see if others have also...
When I let my phone set idle for 20-30 minutes, the webpage loses the header when I click on an item following return from standby. Also, the background is white and there is only one column. Any ideas? The objects still show up with the correct icons and I can click them, but nothing returns the header except closing the browser or webview app and restarting it. Could the web session be timing out while the phone is in standby? When the phone wakes up and the user click refresh or on an item, they are greeted with a white screen similar to the pic attached
Luckily, the issue is easy to recreate on a PC. Here's how:
1. Open up ppc or xb in firefox.
2. Navigate to the webserver and delete the session.
3. In the firefox window, click the refresh button in the header.
4. Pic is attached...
What is interesting is this test causes 17 new web sessions to appear under the web server?!? For the issue with my android phone, only one session would appear, otherwise the symptoms are identical.
PS: I'm willing to donate if someone can fix this
I tried to study this module, but it is very intricate...
EDIT: I found one potential cause late last night. I had minibrowser above the automationbrowser module. 123's instructions said not to do this, so I've reorganized the folders: AB at the very top under default, plugins just below AB, and finally MB right under plug-ins. I'm not sure if order matters that much or not!?! I tried constructing a test once and things worked fine no matter where the folders were... If anyone knows the reasoning behind this, please chime in
Chuck as per your multi-session question: I see what you're talking about. Once briefly on my phone's browser (not the webview app), there were 4 sessions with the same date. I've only seen this once and the app version doesn't do it (at least on android 2.3).
