DSC 1832 entry delay not function properly
martipe1
I have a sensor defined as Delay 1, but when armed as away mode as soon as the sensor is open it triggers the alarm, no entry delay.
What's wrong?
Is the alarm triggering as you exit, or are you able to exit and then it triggers instantly when you return?
What do you have the exit and entry delay times set to ?
Is the entry door visible to a motion sensor?
Check your system times under programming section installer menu, section 005 - make sure there not set to 0. they are usually set to 030 030 030
