ECM-1240 Etherx configuration utility search
mdonovan
I recently upgraded to Windows 7 after a hard drive crash, and I'm having trouble using the Etherx configuration software to find and set up my ECM-1240. I want to set the broadcast interval to something different, but when I start the app and do a search it doesn't find anything. This worked fine on Vista 32 bit, but it seems not on Win 7 64 bit. I am assuming it's the firewall, even though turning it off didn't seem to help. I thought I saw somewhere (I might be wrong) that it uses a UDP broadcast to find the ECM. I couldn't find where I thought I saw this. Does anyone know if this is true, and which port I need to open to let it find the unit? I already allow the application to use TCP port 8083. The Interface Application can successfully receive the TCP broadcasts, it's just the search that's not working.
Any suggestions?
Matt
