Hi BSR
Here in Oz some sparkies refer to those as "Death Sticks" An electrician was electrocuted due to his "volt stick " being faulty....I carry one in my toolkit but only use it to verify that the wire is live (hot).....
Frank
Hi BSR
Frank
Interesting reading. I'm no electrician, but I have done quite a bit in my life... I just happened to have the exact scenario described when I bought my house (at the front door; 3-gang, 2 circuits - indoor and outdoor)... but I was changing things around a lil and adding motion switches and UPB, so while in there, I shut off both circuits and separated the neutrals out. I guess I'm glad I did! Might have made my switch work a couple weeks ago a little more "energizing".That won't always work either. Too many dumba**es are allowed to wire residential houses. If the breaker is off, then according to code, there should be no current on the neutral. None! But what happens is in the cases where you have multiple circuits coming into a j-box, (for example the box at the front door has the outdoor lights circuit and the entry light circuit all coming into a 3 gang box.), these lazy bast**ds doing the wiring just nut all the neutrals together since "it all goes back to the panel anyway".
So now you turn off the breaker for the outside lights and are working in a different box (the other end of the multi-way out in the garage) and somebody turns on the entry hall lights. That neutral is now energized.
All the more reason to avoid track houses... I swear the electrician that did this house was trying to show off with his wiring tricks; lots of odd but technically legal circuits;
You must live in my M-I-L's neighborhood. Over Thanksgiving I had to replace a GFCI in her powder room. I did solve a mystery as to why her post light outside only worked intermittently. I was fed from the GFCI in the powder room. Idiots.
Half of my kitchen is fed through a GFCI near the counter top. The other half-including the refrigerator and lights- is fed from the GFCI located below the electrical panel in the basement. That took me a awhile to find the first time. Both bathrooms (including the lights) share the same GFCI, which is in the master bedroom closet. My only guess was at the time GFCI's were really expensive.
Question - what about a refrigerator in a basement, or a garage, where GFCIs are required?It's not legal where I'm at to run fridges off of a GFCI circuit.
When my house was built I wanted a dedicated 20 amp circuit in the garage, but to get it to pass inspection the builder installed a GFCI outlet.After inspection they said they would install the 20 amp standard outlet. :blink: So I'm guessing there is a requirement for outlets to be GFCI in a garage?!?!
I do have a GFCI outlet on a regular (shared) circuit in there that I use for hand tools and such.![]()
