Elk and water or gas leak detection
scotsman
I have an Elk M1 with a ELK M1XRFEG wireless receiver.
I have some discounts on my house insurance with various sensors.
Gas Leakage Detector
Water Leak Detection
Temperature monitoring system to protect against freezing
Any of these easy to pull off wirelessly with my current set up? And can anyone recommend the relevant wireless sensors?
Thank you!
Thank you!
There is a GE sensor for sensing freezing conditions, the 60-742-95R.
[Edit]
It turns out there is also a TX-E611 flood and freeze sensor.
[end edit]
I don't know of any wireless GE sensors for gas or water leak detection.  But you could take a GE TX-E231 wireless door/window sensor, which has an external contact input, and connect it up to a separate sensor.
For water leak detection, consider a Winland WB-200.  You could also use a GRI 2600, but it will require an external power source.
For gas detection, you could use a Macurco GD-2A.  But it also requires an external power source.  I don't know of one with an internal battery.
