Spanky
The ELK-IP232, RS-232 to Ethernet Module, has been updated and released! Bootware version 1.0.6 and Firmware version 1.0.12 are available on the website at http://www.elkproducts.com/products/elk-ip232.htm
Our customers spoke and we listened -
New features:
1) The IP232 can now be used as a "client" and "server". In other words, it can INITIATE network connections as well as accept them. The "client" will automatically reconnect if the connection is lost.
2) The IP232 can receive incoming UDP network data.
3) The PC Config Utility was also updated (to version 1.1.0) to support these new features. In addition, it now allows you to save IP232 setup data to disk.
Item #1 is the BEST feature. It opens up a whole new world of possibilities. Even in markets other than the security market. Scientists can network test equipment together. Amature astronomers can network their telescopes. Connect an old serial printer to a local network. Connect your vacation home's M1 to your main home's M1 thru the Internet. The possibilities are endless!
IP232 Guru
New features:
IP232 Guru
