Hi-
I've been working on integrating Radio RA2 and my Elk M1. I'm wondering if anyone has any experience with integrating these two systems.
I already have a number of Radio RA2 devices deployed, and the Radio RA2 Main Repeater hooked up to my Elk. I can control lights via M1ToGo, and everything works great.
Ultimately, I'd like to have a couple of different things happen depending on the Alarm state, for instance, I'd like the Radio RA2 system to randomly turn lights on/off when the Elk M1 system is armed to "Vacation" to simulate someone being at home.
I found some decent (but generic) documentation on how Radio RA2 integrates to alarm panels on the Lutron website. I have the link, but for some reason I can't get it to paste into this window (but I can share via email or some other means if someone wants it).
The documentation states that you can set "Phantom button" 92 to On, and that will put set the Radio RA2 system timeclock to "Away mode". In the Radio RA2 software, you can have scheduled events that only fire when the Radio RA2 system is in "Away mode", so everything seems very straightforward.
Basically, I have two questions that I'm trying to figure out:
1.) I can't tell if I'm successfully getting the Radio RA2 system into "Away Mode" by turning on this phantom button via an Elk M1 rule. I need to figure out if this is being activated or not on the Radio RA2 side of things...does anyone know how you can see the status on the Lutron system?
2.) From the Elk training rules on Radio RA2 integration (also in the documentation on the M1XSLU), they cover how to activate a "Phantom button", but it doesn't tell if you it operates as a toggle. In the rules, you set the dim level on the main repeater to the button number that you're trying to press, so to activate phantom button 92, you set the dim level on the main repeater to 92. That being said, I have no idea on how to turn it off. If I set the dim level to 92 twice, does the first one turn on the phantom button, and the second time that I do it, does it turn it off? Or, do I set the dim level to 92 to activate the button for "Vacation", and then set the dim level to something else (like 95) when I return?
if anyone has any experience with this, please share, and thanks for any info that you can provide.
Thanks!
Thanks!
