Elk M1 and Temperature Sensors
alangsk
Can the ELK M1 accept inputs from HAI temperature sensors?
Can the ELK M1 also then accept the humidity readings from the HAI temp/humidity sensors?
If the answer is yes, then I assume there are some settings in the programming to change a particular zone to temperature or humidity.
Sacedog
So besides 1 wire solutions, are there any other temp sensors that do work with the Elk? I have a few places where I would rather not use the large zone sensor that Elk sells (sorry Spanky, but the wife just thinks it is too big :blink: ).
mdavis
How about this one:
ATP-1000 from Automated Environmental Systems
Input voltage: 5Vdc to 20Vdc
160 microAmps
outputs 0 to 5Vdc
