ELK M1 custom settings and temperature evaluation
signal15
I have custom setting 10 set to "15". I also have a whenever rule that checks every 15 minutes to see if certain temp sensors go above the custom setting 10 value. When I do a temp check without the custom setting, it allows me to select F or C. It does not allow me to select the scale when evaluating against a custom setting. So, what temp scale does it expect to use when evaluating against the custom setting?
