I doubt it because it's easy enough to accomplish via rules and the appropriate outputs.
I usually install a 12V (resistor built in) bi-colored LED and install that in a suitable location. I found some jumbo ones on Digikey and while the price stings, it's better than cobbling something together and hoping for a weatherproof result.
You can use the voltage triggers or if the item draws too much, through a relay. I doubt that you'll kill a relay in normal usage.
