johnnynine
I currently have 2 M1XSP serial expander modules, one is for Insteon and one is for 2 HAI thermostats.
The Elk M1 requires that each bus module of the same type have it's own address 1-16. Each HAI thermostat also requires an address be set on itself.
The manual indicates that setting the M1XSP to address 0 requires the connected thermostats have an address of 1-4. Setting the M1XSP to address 1 requires the connected thermostats have an address of 5-8... and so on up to an M1XSP address of 4.
So my question is, since one of my M1XSP units has the Insteon firmware and one has the normal firmware can they both have an address of 1, or do they require different addresses because the both hardware units are M1XSP?
Thanks.
Thanks.
