snakevargas
I've wired my keypad with cat5 as suggested in the manual (two cat5 wires to each rs485 wire). I did this so it would be easy to home run and add the data us hub should I want to run more rs485 devices in the future.
However, since I don't need the capability now, I'm wondering if I can just install the terminating resistor jumper at the keypad and ignore those extra return wires. Will this cause signal quality issues? If its a problem, then I can always install the terminator on the return wires; it's only a little more work.
