wuench
Thanks John and Wuench you've convinced me on adding an M1XEP to my list! Anyone know if the Elk M1G supports socket communications, i.e. will I be able to use ethernet to telent in and test using the ascii RS232 protocol? Basically if I can send the commmands over telnet, I can trick Premise into using the network to communicate with the M1 and not the RS232 port.
Thanks in advance... Sorry I don't have access to the technical documentation until I gain dealer site access...
Yes, you can telnet to it if you enable the non-secure port, then just use the well documented serial protocol (available on elkproducts.com), there is some checksum stuff you will need to do though. The secure port is telnet through SSL with a login prompt.
