Hi Guys,
I'm new to the forum and I'd like to start off by thanking everyone for all the help I've gotten by just reading various posts. I do have a situation that I'd appreciate help with.
I just installed an M1G and I want to add a speaker right next to the enclosure so that when I'm working on the system I can hear announcements. The problem is that the enclosure is right next to my home theater and I want to be able to silence announcements on just that one speaker. Can I install an ELK-800 and use the volume control on that device?
So connected to OUT 1 I would have two sets of speaker wire (18-2) connected (in parallel): one set to my main speaker (ELK-73) on the main level of my home and one set to the ELK-800 which would have another ELK-73 connected to it which would be volume controlled through the ELK-800's volume control.
1. Am I correct in assuming that that would bring my total ohms to 16, even with the use of the ELK-800 since I'm dealing with two 8 ohm speakers in parallel?
2. The ELK-800 is an amplifier. Is it safe to connect it to OUT 1 on the M1G panel?
Thanks for the help!
Jeff
Jeff
