icellama21
Is there a way to remotely or locally reboot a M1 without using the ON/OFF switch?
The switch is locked away in a panel and it is annoying to have to do a service call to reboot it. Doesn't happen a lot, but occasionally the M1XEP just stops working and a reboot of the M1 is the only solution. I already have the power supply to the M1XEP and internet router on a relay which resets most problems, but every blue moon the serial port on the M1 seems to get stuck. Usually after an ElkRP session with a bad connection, but sometimes random. Usually everything else works, just the serial port is hung and no communication of any sort works through the M1XEP.
