Elk M1G with System Sensor i3 smokes?
benze
Hi,
I've been looking into using System Sensor i3 smoke detectors with my M1G system. One thing that the i3 devices support is a need-for-maintenance warning when used in combination with the System Sensor 2W-MOD2 device. The problem with this device, however, is that it requires that either all smokes be connected together and to the 2W-MOD2 device and thereby on a single M1G zone, or require an individual 2W-MOD2 device per zone.
Has anyone used the 4wire i3 smoke detectors with the M1G successfully and configured the M1G to recognize the need-for-maintnance signal from the smokes? Is that even possible? Or is the only way via the 2W-MOD2 device?
I'm actually quite confused my the System Sensor documentation about the 2W-MOD2 device. It seems to relate specifically to the the 2 wire smokes, so that makes me wonder if the 4 wire smokes can signal maintanence condition without it.
Thanks for any advice and/or insight!
Eric
