I'm ready to take the plunge into an ELK system, and I've spent hours (actually days) reviewing the threads and related materials here and on the ELK, CQC, and other websites. My thanks to all of you who have provided so much information, and although my head is spinning, things are becoming marginally clearer.
Much of that reading has been about lighting systems (and the fervor with which everyone has an opinion), and at this point, I think I am only going to dip a toe in the lighting water and initially experiment with (on a trial basis) UPB and Z-wave. I already have some X-10 devices in my home.
I know the M1Gold has the PLC connection that I can use with a PSC05 for X-10 control. I also know that if I want to use UPB (or any other lighting control) I will need the Elk M1XSP.
Here are my questions:
1. Can I use both the PLC on the M1Gold and a M1XSP together or does the M1XSP somehow disable or conflict with the PLC connector and thus the possibility of using both controls simultaneously? I know that I will need the proper UPB firmware on the M1XSP.
2. I assume if I change horses midstream and decide, for example, to go from UPB to RadioRA, I can flash over the UPB firmware on the M1XSP with the proper RadioRA firmware and go forward with the new protocol (abandoning the old one).
3 The ELK manual cautions about having the correct firmware for the lighting control, but how do I, as a DIYer, get the firmware or even know about updates to my chosen protocol? The ELK site limits firmware downloads to dealers...
Thanks in advance....
