dBeau
I'd like to have an output activated whenever a thermostat (aprilaire 8870) calls for heat. It seems that the M1G doesnt allow for this in a straightforward way (or perhaps it is so straightforward I cant see it). I've tried adding a couple of rules to watch the serial communication with the stat but have not had much luck.
WHENEVER THE FOLLOWING TEXT IS RECEIVED: "SN1 HVAC=G-Y1-W1+Y2-W2-B+O-^M" THROUGH PORT 3
THEN ACTIVATE fp-on [Task 6]
WHENEVER THE FOLLOWING TEXT IS RECEIVED: "SN1 HVAC=G-Y1-W1-Y2-W2-B+O-^M" THROUGH PORT 3
THEN ACTIVATE fp-off [Task 6]
I have verified that the text I am looking for does get sent by the stat when heat is call for and when it is no longer called for. Should the rules work? Is there a simpler way? Am I missing something with the rules above?
Thanks!
Thanks!
