johnnynine
When I send multiple consecutive commands to the RC80b thermostats, they sometimes don't get the setpoints updated properly. I'll come home in the summer to an 88 degree house even though a rule ran earlier in the day to set the cool setpoint to 81.
I have rules that activate either hvac economy mode task or hvac comfort mode task.
The Problem
The problem is that the temperatures only get set on the thermostats about 25%-50% of the time. This has been going on all this year at least.
Test 1: Confirmed that the tasks are running when expected.
I confirmed that the tasks are actually running by setting up an email as the 1st action in each task and let it run that way for a few days. I would get an email 100% of the time, but the thermostat temperatures wouldn't always be set.
Test 2
I also did another test by manually setting the upstairs thermostat to a bogus temperature which caused the "Remote" LCD text to disappear on the thermostat. I then activated the economy task. The "Remote" LCD text reappeared as if it was updated by the Elk M1, but the cool setpoint temperature we not set. I should probably do some more testing on this.
Test 3
If I program a rule to just set the cool or heat setpoint, it works 100% of the time, so I don't think there is a serial communication issue with the thermostats.
The Rules
WHENEVER HVAC EconomyMode (Task 4) IS ACTIVATED
THEN SET Downstairs (Tstat 1) HEATING DESIRED TEMP TO 68 DEG. F
THEN SET Downstairs (Tstat 1) COOLING DESIRED TEMP TO 88 DEG. F
THEN SET Downstairs (Tstat 1) TO AUTO
THEN SET Upstairs (Tstat 2) HEATING DESIRED TEMP TO 68 DEG. F
THEN SET Upstairs (Tstat 2) COOLING DESIRED TEMP TO 88 DEG. F
THEN SET Upstairs (Tstat 2) TO AUTO
WHENEVER HVAC ComfortMode (Task 5) IS ACTIVATED
THEN SET Downstairs (Tstat 1) HEATING DESIRED TEMP TO 73 DEG. F
THEN SET Downstairs (Tstat 1) COOLING DESIRED TEMP TO 82 DEG. F
THEN SET Upstairs (Tstat 2) HEATING DESIRED TEMP TO 73 DEG. F
THEN SET Upstairs (Tstat 2) COOLING DESIRED TEMP TO 82 DEG. F
Please help,
Johnny
edit: typo
The Problem
Test 2
Test 3
The Rules
Please help,
Johnny
edit: typo
