Elk Speaker Volume reduction?
Greets all,
I'm interested in a way to reduce the volume to certain Elk speakers during certain times of the day. Currently I am using an output expansion relay to have the Master Bedroom speaker either binary ON or OFF -- (OFF during the times when the baby is likely to perceive any sound as a cue to start the day. A baby awake at 6 in the morning is not popular with the wife)
I'm not concerned with missing any critical fire/burglar alarms as there is no sleeping thru the piezo wall of sound, but rather than an OFF speaker, how about a 1/2 volume speaker. It's messages like "Motion in Driveway" that are of interest -- not critical but interesting to me in the night. (more than likely a deer, but you never know)
So... could I just put a simple resistor in line with my speaker (shunted in and out with relay) or should I use a full blown single gang speaker volume control? If so, how would one calculate the resistance needed and would heat dissipation be an issue?
Any help would be greatly appreciated.
-Chuck
Chuck,
The simpliest way to control volume is what you are doing. Shunt a resistor in and out of circuit with a relay. The output amplifier does not care and will not hurt anything.
Thanks Spanky. I guess the question is, what power resistor should I use. I'm guessing I'll need something rated at 5Watts, but what Ohm? I suppose I could just buy a handful and play around, but honestly, I can't even guess within three orders of magnitude what it would take. Are we talking kiloOhm?
Try a 1 watt, 30 ohm resistor, to start, then I would go from there.
One watt should work fine. For every half in power, sound drops 3 db, which to your ears is slightly. You'll have to experiment, but a 20 - 80 ohm is probably what you are looking for.
Chuck,
A quick diagram would help the circuit-challenged people... ;) Could you post one? Oh please...
