Trying to figure out how to wire up 24VAC Solenoid type residential sprinkler valves to be controlled directly by the ELK. Dry contact relays won't work since I understand 24VAC needs to go to the valve to make it work. Could incorporate a transformer and a dry contact relay for each zone, but for 8 zones that would get real messy real fast. Could get the Elk to run a WGL Rain8net, but that gets expensive considering I'd also need to get a serial port expander (ethernet expander is already using the serial port).
I guess my question is: Do any of you control these types of sprinkler valves directly from the ELK, and if so, how did you wire it all up? Can the voltage outputs from the M1G drive a 24VAC sprinkler valve?
Really like this board... lots of info and great folks here.
Thanks.
Thanks.
