ELK WSV (Water Shutoff Valve) Wiring Clarification
I have my WSV installed, nice piece of equipment. I have an external power supply for it that will also power some GRI water sensors....my question is can +12v be continuously supplied to the valve? Or should it be a momentary for each fuction....
IE:
Apply +12v to white or red wire for 5 seconds, then kill voltage OR
Wherever +12v is seen (white or red wire) the valve will either open or close (and it has its own logic/relays inside to stop motor once action is completed) ---> pretty sure this one is right since you would need constant power to the valve for the green wire to work properly. So do i have this right, the valve ALWAYS sees +12v and does its own internal switching to actuate the motor for however long it needs to?
