ElkRP acting weird
Hermanus
When I open ElkRP connect to M1G and click on the Status menu button it open the Status dialog box, but scroll to the bottom of the list displaying the Input Zone, so I can only see Zone 10 – 16 and it does not allow me to scroll up.
Also there is no Submit|OK button or Cancel Button nor an [X] in the window titlebar to close the New Rule window. Thus once opened I have to go to Windows Task Manager and End Task to close ElkRP.
I am running ElkPR 1.6.24
Although we've taken steps to fix this issue, it continues to pop up occasionally. To work-around it until we can finally put it to rest, right-click your desktop and select Properties. Click the Appearance tab, then the Advanced button. Under "Item" select Scrollbar and set it's size smaller - to perhaps 13 or so. You may experiment to find a size that works well. Click OK, then Apply and OK again, and test the new setting.
ELKRP Guru
Elk Products, Inc.
Updated
