IVB
Dumb question, what's a RIB?JimS said:Why not just keep the existing light fixtures and remove the sensor. Plugs for the holes are probably $2.
So the cost is
LV motion sensor $90 (your number, think you could get it slightly cheaper)
RIB $15
Plugs $ 2
Total $107
Almost the same cost as a new motion light. (the sensor is cheaper and likely the only thing that needs to be replaced)
Think you said you already had the elk relays and such to run through the HA system. The only pain may be where to put the RIB - may require some HV wire runs.
And yes Pete, I realize I'm opening myself up for abuse there
