Flags Showing on Omnitouch
lvmikel
Hello all, just a quick and hopefully easy question.
I am using flags to control a few time based automation items in my programming.
When you go to the Omnitouch or Snaplink, these flags show up under Control.
If you go into Control, it will show all your Rooms, but it also lists all the Flags you have configured.
Any way to turn off the display of the Flags under the Control section of the display?
Thanks.
Mike
If you are using Snaplink on an I-Phone simple process. Go to the CONTROL screen and press edit in upper right hand corner. Then select the flag you want to hide and a red box will come up that says "Hide" select this hit done and it will not appear in the list again. You can always bring it back by hitting Edit again and unselecting it. You will lose this configuration when you do an update from the controller. It works very similar on the PC based Snaplink so imagine it is the same on the Android app.
Looks like its a no-go on my Android...
Don't see an Edit button.
Also...any ideas on removing it from the Omnitouch 5.7 display?
No on the Omnitouch 5.7's, Omnitouch 5.7e's, Omnitouch Pro software and Snap-Link Version 1.1.22.290 for Wintel.
