drvnbysound
I'm looking for recommendations for installing discrete wired sensors for exterior french doors (new construction). Hidden/flush mounting is preferred if possible.
drvnbysound said:Well, I'm asking for 2 different installations really; my detached workshop which will be completed soon which will have wooden doors, and a friends home which construction hasn't quite started yet (unsure on the doors).
Are you referring to using a standard sensor, or a flush type?
I have no idea about the home, but I highly doubt there will be room above the door of my workshop (header) - which is why I was looking for other options.
wuench said:Usually there is enough of a gap between the door frame and the header (so it can be shimmed) to run wire before installing the interior trim. And flush mount sensors are small enough to fit in a half inch door frame. It would be easiest to drill the hole in the jack studs before inserting the door, and maybe even running the wire and taping it to the header.
