When wiring up a panel, does it make sense to add a fuse to each power consuming sensor, like motion sensors, etc.? At first you may think, no that's crazy, but when you think about it, without fuses, if any sensor shorted, or any power wire was pinched and shorted, it would bring down your whole system. Yes the panel has a resettable fuse, but that means every device would be in alarm.
You add an EOL to the sensor wires, doesn't it make sense to also fuse each power wire?
If anyone has ever done this, do you know of a small bank of say 1A fuses you can buy to do this? Then if a power wire got shorted, it would be easy to find the offending sensor.
