Desert_AIP
Anyone know if it is possible to wire a second set of GDO IR sensors in parallel with the primaries?
I want to keep the existing sensors at the bottom of the door and add a second set at about 4' to protect against closing the door on a car not pulled in far enough.
The cars have enough ground clearance that they can stick out into the path of the door even though the ground level sensors are clear.
This is on a Genie GDO.
ETA:
After a bit of internet research, it looks like the output of the sensors transitions from hi to lo at ~155Hz.
So the GDO uses a missed pulse detector when the beam is blocked.
When the beam is blocked it's output is constant hi.
I'm guessing two things.
The oscilaltors wouldn't be synched, so the pulses would arrive at psuedo random times, may or may not cause problems.
If one sensor was blocked (continuous hi output) the other could still be sending pulses, making the second sensor useless.
Hmmm...suggestions?
ETA:
Hmmm...suggestions?
