glass break in a kitchen
newalarm
What is the logic behind not having glass break in the kitchen? If the GB are only on in 'away' mode, then it should not be a problem? or in 'night' mode, the risk would be reduced (unless someone drops a glass and shatters in middle of the night.)
the only thing i could think of was particulates/grease in the air could mess up the microphone sensor.
Thanks.
If you have that much in the way of particulates/grease in the air, you have bigger problems, and/or the GBD isn't located properly.
The better units self test and adjust their gain, so really is not a huge issue.
Thank you DEL. I guess particulates can be problem over time in a kitchen without a hood. but even then, grease tends to settle down, not so much to vertical surfaces.
Thanks.
The real question you should be asking is: Do you have the correct spacing, distance, and mounting location to effectively use a glass break detector??
1. Follow the manufacturers recommended installation guide lines with respect to distance, and orientation.
2. Avoid areas of heavy drapery or materials which will mask the detection.
3. Know the limits of your sensor as some will not detect the sound of broken glass which is plated, wired, or tempered.
4. Some sensors do not provide full audio and infrasonic spectrum analysis.
5. Many sensors are directional so proper orientation is paramount. Others are provide true 360' detection but mounting is critical for these sensors.
6. Always perform a walk test, and test the sensor in real world conditions. Some brands offer testing rigs to ensure the full spectrum is tuned 100% for reliability.
7. Rattling of the key ring, clapping your hands, and other forms of testing show you a low grade sensor.
Teken . . .
Thanks Teken. I was asking because the literature says specifically not to mount in kitchen. But we have a large open kitchen. I mounted according to instructions. Have not yet tested it. but i read that a clap and dropping keys can mimic the sound of breaking glass. I considered a glass break tester but wanted to avoid cost.
We will only use them in Away mode or night mode when kitchen see little use.
Sensor is the GE shaterpro 3 Sentrol 5812NT.
I've had issues with Shatterpro's and Shatterboxes, so I would avoid like the plague. YMMV, but I believe there are units out there that perform far better.
