lurlette said:Sorry,wuench,ral, that was my bad, it's 12 volts, so just to clarify, I can just connect all of them ( say about 7 ) to the 12vaux on the M1 panel right? Thanks
lurlette said:Ral, sorry, I just want to make sure that I do it right, so for e.g say the 2600 under kitchen sink wire red to + black to - green and white goes to a zone and powder room sink red to + and black to - and same for the others, is that how I am supposed to wire them? Thanks.
RAL said:You should connect the red wires from all the 2600s to VAUX+ and all the black wires to NEG on the M1.
Then daisy chain the white and green wires from the sensors from one to another. I.e. White1 to the M1 zone input, green1 to white2, green2 to white3, green3 to white4, green4 to white5, and green5 to M1 zone NEG.
If you are using EOL resistors, place the resistor at the last sensor (green5) and connect the other end of the resistor to the cable wire that connects to the zone NEG terminal.
drvnbysound said:Unless he wants to dedicate a zone to each sensor... right?
I know in some cases (locations) I may want to know specifically want sensor caused the issue so I know where to look right away, rather than having to check every water location.
