Hey Guys,
Bit of a noob question - i'm trying to wire a 4 wire gri 2600 water sensor to my elk m1 and it mentions that this should be wired as a NC sensor. When I look at my elk m1 (had a contractor do the install and wiring) all other door sensors use only 2 of the 4 wires i.e only red and black are connected to the panel with a 22k resistor on the end of the red wire
Am I to follow the same method for these water sensors or should i be using all 4 wires ? The instructions for the water sensors document that all wires need to be used with the resistor on the green/ yellow wires.
Appreciate the help
Appreciate the help
