@heffneil: HaikuHelper 1.1 will fix the sunset/sunrise not being refreshed.
@bighorn:
Its quite easy to do, run Airport Utility and connect to your router:
- Click the Advanced icon (the gear) and then click the Port Mapping tab.
- Click the [ + ] button to add a port mapping
- For Public UDP Port(s) and Public TCP Port(s) enter 4369
- For Private IP Address enter the IP address of your HAI controller as it is set on your network.
- For Private UDP Port(s) and Public UDP Port(s) enter 4369 or the port your controller uses if its different. The default is 4369.
- Click Continue.
- Enter "HAI controller" or any other descriptive name for the Description field
- Click Done.
- Click Update.
That's it... you should now be able to connect to your HAI controller via your Internet IP on port 4369
You can find out what your Internet IP is by going to
http://www.whatismyip.com/
You can also sign up with a Dynamic DNS provider to have a hostname/domain address that you can use such as myhome.dynd.org. They usually provide a little app that runs on your computer that updates the domain to point to your IP address.
