AnthonyZ
That would be an awesome addition.Maybe we can add a setting on whether to show the auxiliary sensors in the insecure zones. It really depends on what they are used for, whether it's useful for them to appear there.
http://192.168.0.105:8008What are the values you are entering into Haiku?
It's working fine for us here in Haiku.
that's a good idea!Maybe we can add a setting on whether to show the auxiliary sensors in the insecure zones. It really depends on what they are used for, whether it's useful for them to appear there.
SJHart: And the URL is exactly: http://x.x.x.x:8008 ?
PTZ is disabled right?
What appears on the screen when you try to view the camera?
Here's what we use and it works:
What model is your camera again?
Also, can you check the camera's firmware version (from the web admin interface)?
@SJHart: Interesting, we've tracked it down to being an issue only on iOS 4.3, its a bug with the WebKit framework looks like. We've been testing with the next major update from Apple here and it was working fine. So, the next update from Apple will correct this. In the mean time we'll continue to look for a workaround.
We're going to be adding H.264 support as well, so that would work soon too. Any idea what the URL for the H.264 stream is? I'm going to look around now.
