Hello, New user to HAI and to this forum. Thank you in advance.
I have started to look at the testdriver and console sample as part of the java SDK/API. Unfortunately I'm more of a unix hack then a Java programmer so am interested if anyone has developed (or likes a project) a simple command line tool that converts the current status of zones, temperatures monitors into a audit trail output.
Having stumbled through the testdriver code it contains most of the information ideally it would be great of the output was formatted slightly more friendly. I can then run this command line tool every 5 minutes vis a unix script and capture the results etc.
Im hoping that this would be useful to other unix hacks out there as well as system integrators who want to use a simple CLI.
For example something like the below
> ./omnstatus -f configfile -t zones,temperatures
20150408:12:05:00|101.168.1.10|Hallway|Zone|NorthWindow|Open
20150408:15:05:00|101.168.1.10|Hallway|Zone|SouthWindow|Closed
20150408:15:00:00|101.168.1.10|Hallway|Temp|Downstairs|23
> ./omnistatis -f configfile -f log
20150408:11:00:15|101.168.1.10|log| Message ABCD Received
20150508:11:00:16|101.169.1.10|log| Security Disabled by ABCD
ie possible command line options could include
-f is a config file with connection information such as IP address, username, passcode etc
-t is the type of items to report i.e. zones, temperatures, log file.
ie possible output structure could be something like
timestamp
ip address of the controller
type of event
name of zone, temperature etc
current status of the zone etc
Im an optimist so I'm hoping that there is someone out there much cleverer then i that can help.
A
timestamp
type of event
A
