Hey all,
Installing a new ELK M1 system and jsut bought the new Omnistat 2's. The issue is that I'm planning on having a Misterhouse system in place as well. It appears that I can either connect the Omni to either the ELK serial interface OR a misterhouse serial interface.
So my question is: Does the ELK expose thermostat control via it's API? Can I issue a command to set the temp from misterhouse and/or perl to the ELK to set the Omni temp?
Also I want to place temperature sensors in each room, if I connect these to ELK, can I poll each via the API too?
--David
--David
