I have the M1G and besides the keypads I have been happy with the system. I use homeseer also.
The problem is that my lighing doesnt work right with the ELK. I use Z-wave at the moment and really dont want to change every dimmer/Switch (60+) of them. I am using the Leviton RS-232 Z-wave for connection to the ELK. and Homeseer also with the Z-troller. When I turn on a Switch/Dimmer the light will respond and turn on, after a few sec the M1G will show that the switch/dimmer jumps too off right away, leaving the Light on! also I dont see what is on or off. it just shows everything as off. To turn off the light with the M1G I have to turn it on and then off before it jumps to off on it own. This is true for keypads, Web Access, and EK M1(iphone).
as for hand held devices I have the Cooper AspireRF. I did go out and but the Leviton remote to try that just as the Instructions say too, And still the same problem. 80% of my Switches/Dimmers are the Cooper Aspire RF and the rest are the Leviton.
A while back I did go and get the UPB from HAI and one Switch to try that and it had the same Problem also where the it would go right off after a few sec. also.
I have tried to do it with Polling and with out (Jummer setting on the Serial Modual.)
I guess I am at the point of thining of Changing out my M1G to the HAI OMNIPRO II if I cant get this to work right. Then again I dont know if I HAI will have the same problem. Just thinking that HAI might be better at lighting even thoe I know the programming is hardder but that can be learned.
Thanks in advance to all your Help here!
Please dont take this that I am saying HAI or ELK is better! But I am open to your Sujestions on this matter too.
Scottp73
Scottp73
