The inherent issue with running multiple 4 wire smokes on a single panel, assuming they're installed correctly and with a power supervision relay, is that on a reverse polarity (tandem ring) you are going to throw all the zones into trouble or in the case of a fire reset, the same....causing a whole load of events and activity to hit the M1 at once. If monitored, expect the same amount of events to keep the phone (or even cell) tied up for an extended period of time. If you get billed by amount of activity by your CS (some do) it's not a pretty scenario in that case either.
If you attempt to separate out the fire reset portion it's going to make the panel more difficult to use for an end user, especially in the case of resetting after a false, necessitating more rules and outputs, assuming you're going to attempt a "reset X detector" only and not a global.
Unless you have a huge install, I would not recommend it personally.
