I'm setting up an 1-wire system that has HVAC monitoring boards a fair distance (~100ft) from my computer. All is fine with the HVAC units disconnected but when the HVAC inputs (std 24vac sources) are connected, I get numerous exceptions (running with Java software) and frequent sperious readings. Several experiments have definitively located the source of the problems as the HVAC inputs. Tests show that the long cat5 cable is not the problem. A common between the 1-wire system and the HVAC inputs has been verified. Although I don't have the instrumentation (oscilloscope, etc) to quantify it, I suspect the HVAC signals are rather noisy. The air conditioner turning on and off creates the biggest problem.
Any suggestions on a way to clean up the HVAC input noise?
I suppose I could go to the 8 channel I/O board which has optoisolators on the input side. If I do switch to the 8 channel I/O board, anyone have some Java code for it?
Thanks in advance.
Thanks in advance.
