I'm working with the Jasco/GE 45609 switch. I've been trying to hook this thing up but haven't had much luck getting it to work. I'm aware of the air gap switch.
To keep it simple, I'm trying to install it on a light circuit that has only a single switch located in its own switchbox. I definitely have the ground, line, and load hooked up correctly. The neutral wire I'm not sure about. In the switchbox I have two neutral wires twisted together, one coming in with the line and one with the load. I'm not sure which goes to the switch, but from everything I've read the switch requires a neutral to operate. I think the neutral from the load should be hooked up to the switch, but then what do I do with the other neutral? Any direction would be awesome.
