bbruck
I connected my Venstar 1700 this winter, and now that the temperature in DC is 90 degrees, I've found that when I turn on the A/C, the heater comes on instead - and in fact the temperature went up to 99 degrees before we figured out the problem. But what's the solution?
We have a lennox heat pump and all the wires except one are clear. Looking at the unit, here's what it says:
R (Lennox) = Power = R (Ventar)
G = Blower = G
W1 = Heat 1 = Y1
C = Common = C
But here's the problem:
The Lennox has two more wires:
Y1 (yellow wire) labelled Cool 1 on the Lennox
O (orange wire) labelled Reverse Valve on the Lennox
Every one of the wiring diagrams for the Venstar shows only ONE of these values - and indicates that it should be attached to the W1/O/B terminal.
So if I have both of these wires coming from the heat pump - what do I do?
G = Blower = G
W1 = Heat 1 = Y1
C = Common = C
