SpeedDemon
Hi,
It's time to order and install an Elk M1 Gold that will be used for security + light HA duties in a new construction. Other HA systems to be installed include Centralite Elegance XL, CQC, Rainnet, Aprilaire 8870's, and Nuvo GC. Unfortunately I'm pretty much on my own on this one, the alarm installer who's putting in the Elk mostly does general alarm systems and can't help me much on using the M1G beyond alarm functions.
As a beginner in all of this, I have some general questions regarding the Elk. Help with any of these questions is appreciated!
1) What are the 10 50mA outputs on the M1G panel typically used for?
2) Am I covered for communication with just the serial port expander talking to CQC/the PC (and maybe direct to a couple of the other HA components given the expander has 3 serial ports?) or do I need the ethernet port expander for fuller functionality?
3) Should I use the Elk-branded temp sensors for various interior room/exterior temps? What type of wire should be run for these? In the case of flush-mount (hidden) sensors which Elk doesn't offer, what is recommended? Also, for my roof, is the probe on the Elk M1-ZTR ok for direct sunlight?
4) I've noticed some Elk owners mention using speakers indoors instead of sirens. Is this because you could still play an alarm siren over them, but also dual-purpose them for announcements? Is the siren that would play over the speaker as loud/effective as a dedicated siren? Which part # is recommended?
5) Assuming folks agree that interior speakers are the way to go over interior siren, what's a general rule of thumb for quantity/placement? Our house is all-bedrooms upstairs, and the typical remaining rooms downstairs. I will guess placement in my case is two for the 2nd floor: master bedroom, hallway of the other bedrooms, and maybe 1-2 in a common area of the "open-style" first floor (kitchen/family/entry). Maybe one in the outside covered-patio?
6) Is it really worth the expense to buy & wire separate motion detectors outside that would then activate exterior lights via the lighting control system, vs. using unintelligent standalone motion-light combo hardware?
Here's my order list. If anyone could comment regarding tips and if I've covered my bases that would be great. Including -- is there any useful but not mandatory functionality I should be wiring for that isn't addressed below?
- Basic M1G package (panel, keypad, 2 contacts, 1 motion, siren)
- Aux can, zone expanders, add'l keypads, contacts for openings, battery backup
- 2 exterior sirens
- 4 interior speaker/siren ELK-SP12F (??). Is something needed to drive this beyond the Basic M1 pkg?
- 1 ELK-M1DBH (Data bus hub)
- 6 total interior motion sensors (some for HA use rather than security)
- 3 total smoke/heat sensors. (Garage, 1 upstairs loc, 1 downstairs loc)
- Wire for watershutoff valve (Cat5?). Elk's WSV itself seems too pricey
- 2 Garage door sensors (recommendation on which sensor to use?)
- 6 temperature sensors: 4 flush-mnt for bathrooms, 1 roof (ELK-M1ZTR with probe exposed to direct sunlight?), 1 covered patio (ELK M1ZTS)
- Contact closures: Mailbox, any exterior-located panels (electric etc; phone panel isn't located outside)
- 2 Cat6 to laundry room to cover: moisture sensor and 2 future "washer/dryer - Done!" indicators
- Moisture sensors (wire type?): 1 under kitchen fridge, 1 near plumbed coffee maker
- Phone/Doorbell Ring detector (ELK 930)
Thanks much!
- 2 exterior sirens
Thanks much!
