politics123
Your hot water tank should be able to keep the hot-water "hot" for quite a while:
1) The water can become quite hot. Today was a 55-60 degree day, but we ended up creating 160 degree water (you will definitely need a tempering valve!). After about 5 hours of sun, the top of my tank is 160-ish degrees, the bottom is around 150.
2) Typically, I'll lose a few degrees overnight, but really not that much
Of course, when you use the hot water (say at night), cold water will enter the water heater. The real question becomes whether your backup source heats the cold water, or whether you disable it and let the sun work its magic the next day. I use an ELK 9100 to control my water heater... and some basic automation rules for when to power the heating elements and when to wait.
Good point ... I hadn't thought about overheating the water during the day to utilize the solar energy while you have it.
I wonder how efficient you could get with a solar system feeding a storage tank and feeding through a tankless heater. Seems like you might get the best of both worlds if you can ensure the system is sized to work when you get that week long blizzard in winter.
Yup. Super-heated water combined with a tempering valve also has the added benefit of making an 80 gallon tank "seem" larger than that. (my 80 gallon tank results in about 100 gallons of 120 degree water)
You'll definitely need a backup heat source. But I don't think tankless is really going to help you out. This is because you need a solar storage tank anyway (either a normal water heater or a specially-built solar storage tank), and these come with heating elements. Solar storage tanks tend to be super-insulated, and if you use a normal water-heater, you'll add insulation (see my post above... $30 is pretty cheap upgrade)
Solar system should be sized to handle 75-85% of your annual hot water needs. So really, you're looking at the extra cost of a tankless heater compared to the cost savings of heating 15-25% of your water via tankless vs. with the tank you already bought, which already has good insulation.
Don't get me wrong: if you're going tankless it for environmental goals, go-for-it (but remember to weight the environmental cost in constructing the tankless sytem) but I don't think it'll help your break-even.
As for snow...
1) especially in the north, you're going to want to mount the thing at a steep angle (usually equal to your longitude). Mine is mounted 45 degrees, and I'm only 39 degrees north. This gives you better winter performance and worse summer performance, but you don't realy need the help in summer
2) The steepness of the moutn should help the snow from accumulating
3) These things absorb heat even when its not sunny. I'd bet that it melts the snow off. However, you should confirm that with a local installer
www.findsolar.com in the US and Canada is a great resource for local installers
mh
