I'm using TMEX to read the DS18S20, exactly as the data sheet says. COUNT_REMAIN is always zero. In the 1-wire viewer, you can select the resolution and it flashes "setting resolution". I looked at the view source, and it appears to be set something on the device, but I couldn't determine exactly what it sends. There is nothing in the data sheet about this.
So, how do I get the extended resolution?
Thanks!
Seth
Thanks!
Seth
