What do you mean "monitor"? You could use a pulse stretcher (ie one shot timer) to make the circuit to be constantly open (or closed) while the real sensor fluctuates.If I had a Normally Open sensor that cycled roughly every half second between open and closed during alarm, how would I monitor it on the ELK M1G?
Nice job on the electronics.....the rest can be easily achieved in the M1.Ok, so here's the exact scenario. I want to monitor the low salt LED on my water softener. So I picked up an optoisolator for $3. As a test, I wired it in parallel with the low salt LED using test leads, and the other two pins go closed when the LED lights up. Works great in that respect.
The problem is, I didn't realize the low salt LED blinks when it's low on salt, instead of just staying on. It's 1/2 second on, 1/2 second off. Can I use a capacitor to smooth out the signal? Or is that not going to work?
You can use an Elk 960 or similar to convert the pulsing signal into a nearly steady signal. It looks like the Elk 960 may reset every 60 minutes, I cannot tell for sure.
http://elkproducts.com/products/elk-960.htm
My M1 does not log zone status changes. Does yours?Nice! Now, the next question is, how do I turn off logging for a particular input. I don't want to fill my logs full of crap when the LED is blinking.
My M1 logs alarms, arming, and disarming, and a few other miscellaneous things, but not zones unless they cause an alarm. I assume your LED zone will be a non-alarm zone anyway, right?
In the ELK logs? That would be quite unusual. Must be a feature of Aux1. Type 16 doesn't get logged.I have a motion sensor set up as type Aux1, and it shows up in the logs.
I'm very rust on this, but I would try;
Ground one side of the optoisolator, drive a 220 ohm resistor in series with a 10 microfarad cap connected back to ground.
Use the common point of the R/C as your zone input.
Then, with the 2200 ohm pull-up resistor in the ELK, you would have a half cycle pulling towards 12 volts with a time constant of 22 seconds, then a half cycle pulling towards common at a time constant of 2.2 seconds.
That should stabilize somewhere below the threshold.
