IVB
What is "a lot" of cabling? My main raceway has something like 30-50 runs, with perhaps another 10-15 low priority ones that I should do at some point.
Also, the jhooks you linked to seem like they're only perhaps 1" wide max at the bottom. Is that really much better than the hanging hooks I used that are perhaps 1/3" at base? I trust your opinion, just surprised that such a minor extra width results in much better quality.
DELInstallations said:Cable tray and ladder rack, by the time you put in all the fittings and consider the bends, changes in elevation, etc. is going to be the most expensive and complex method to support LV cabling. Usually it's used in locations where there is a LOT of cabling or the need to pull in a LOT of future cabling is going to be needed...or in the case of some larger buildings, a way to pull the cabling in without disturbing staff, as much as that is possible.
