CrossFunction
This has been two week of reading the manuals and trying to add another node/switch to the SXP serial to Levitron zwave controller.
I have an elk M1 gold with the SXP serial controller and the original installer put in 5 zwave switches which work great through eKeyPad and the elk RP for rules, but I really want to add about 3 more GE dimmer and on/off zwave switches to the network, which is easy enough, but im not sure how to know what address the new node is, and how this information is added via the ElkRP. Im using the GE advanced remote to manipulate the zwave network.
1. i have the S8 jumper set to 0 so that it will poll the network (which i suppose updates the list in the m1)
2. Is the elkRP application used to do anything other than name the node at the line item address?
3. Using the keypad, menu 2, lighting, I get odd results when applying rules that used to work before adding this dimmer, as if there are order issues and the named nodes in lighting on the RP are off now.
I have tried to "recover" the network information thru the ge remote, and also did a resend of the information through the remote thinking this would help align my disparate node names.
Is the adding of lights/nodes done in the keypad? Is there an easy way to see the status of the network and what address is currently associated with each zwave network node? After two weeks of ending at dead ends Im seeking someone with a bit more experience than myself. If i cant get a simple switch going i know that Ill really be in deep when i am requested to add the zwave valves for watering the yard.
Thanks in advance.
System is Elk M1g, with SXP serial expander, and ethernet interface, one area and 16 zones.
Thanks in advance.
