The search engines aren't helping me out much here.
I'm wondering if any of you have seen an incandescent dimmer (120vac) that has 0-10vdc control, or maybe that could adjust dimming based on a low voltage contact closure? This dimmer would be located in a remote location, not in a switch box. I've found some solid state relays that take 0-10vdc, but they output voltage is 20-300vac. I've also found ss relays with output voltages topping out around 120vac, but they have odd control voltages (by odd, not a standard I'm familiar with.)
